Canon 350d manual mode not working
Discussion in 'Technical Troubleshooting' started by Bali014, Jul 23, 2022.
  1. Bali014
    Bali014 New Member
    Canon 350d
    Hello guys!
    Recently I started using my fathers old Canon 350D camera, and he told me that don't even bother trying Manual mode because it doesn't work. He was kind enough to lend it to me, if I could fix it for him that would be awesome.
    The problem is, if I switch the dial to Manual, it just stays in Av, and if I try it from the other way, it switches to Av mode. It just doesn't register that it's turned into M mode.
    I googled for around 3 hours, and didn't find this exact problem anywhere.
    Have any of you ever encountered something similar?
    Mpb.com in uk have a couple of well used ones for £26 in functioning order, they just cosmetically rough, if it was a camera i wanted to fix and couldn't get the parts new or from a good second hand parts reseller i'd be buying one of those for £26 and watching a tear down vid on youtube, one of the proper ones there are a couple of spoof ones for video effect, kai did one spoof
    if you not confident then you could end up buggering up the old mans camera worse
    reason i suggested it because its exactly what i did with my M50, i had already bought one with a blow main board for spares for the grip covers for later on when mine get bad, turns out i needed it a few months ago for the D-pad as mine started to miss a few times when i pressed it, i had already watched a teardown vid and pulled the spare one apart a few times before just to see what was inside it, so yeah,
    £26, doesn't matter if you mess that one up, if you do don't tough the other one lol
    it could be that the switch is just the culprit
    one thing to be wary of is the capacitor, i just took the gamble on mine and went for it and was fine but there are warnings on those for a reason, research that and make your own mind up or ask others
    Bali, im not sure where your from, but the camera is 17 years old and it is likely an electrical issue inside. As Caladina mentioned a parts camera can be picked up cheap if your so inclined to open it up and try to fix yourself. Otherwise you can upgrade to something half its age for a very modest investment if you want to do that.... frankly I couldn't live in AV only it would drive me nuts.
    Welcome, Bali, I have two 350Ds which I use in my photography class. Fortunately both of them work fine.
    Now my I suggest that if you have no experience stripping down and repairing these cameras, leave it alone as being your father's camera, may not be to pleased about it.
    These are lovely little cameras and can be purchased cheaply form Ebay.
  5. Bali014
    Bali014 New Member
    Canon 350d
    Thank you all for the suggestions.
    I think I'll invest in a newer model when I think I'm ready for manual photography :)
