canon IXUS 870is problem with viewing pics on camera
Discussion in 'Technical Troubleshooting' started by swaps1122, Jul 31, 2023.
  1. swaps1122
    swaps1122 New Member
    Ixus 870is
    New here and new to this camera, only just got it. works fine and takes decent pictures but please have a look at the attached picture. this is what I see when I try to view on the camera and I dont know how to get it back to just the picture showing. If I view slide show its fine and the pictures are normal when I transfer them to pc or read the memory card. Any suggestions please ?
  2. Thumbnail
    UK
  3. swaps1122
    Ixus 870is
    There are only a handful of buttons i think would be applicable, display would rotate between display types, also this appears to be a zoom function of the image, so the magnifying glass probably was pressed and you can press it till it returns back to not magnified, usually you can navigate around the magnified image with the grid / arrows depending on the camera.
    Edit: a closer look at your camera, being its a point and shoot, the lens zoom control on top is likely what is zooming the image.
  5. Thumbnail
    UK
    The information you want is on page 1095 of the manual, see here:
    Hope this helps Alan.
  6. swaps1122
    Ixus 870is
    Thanks, that helped a lot I found in the tools a reset button which has taken it back to factory setting and that has done the trick.
    Its working as it should now.
    Thanks Alan
