Canon Pro 1000 Printer Issues
Discussion in 'Technical Troubleshooting' started by Califmike33, Jan 7, 2024.
  1. Califmike33
    Califmike33 New Member
    Canon Pro 1000 printer
    Got a brand new Pro 1000 printer, put the ink in, ran thru the setup and I'm getting error code 5200, the printer refuses to align the printer head, errors out every time, and the printer won't print in color, only B-W, no color at all and i have plenty of ink in the printer ???????????????? Do you have Do you have any ideas on what's going on?
    Well I was able to put the ink in my pro 100 and complete the setup and print a test print.
    The error is a ink error which tells me they are not registered as snapped in, or snapped in the right spots. I would unplug int open the whole thing up re-seat the ink and put it back together and plug it in and try the setup one more time. If that doesn't work you probably have to call canon. They will walk through the steps with you and confirm if the printer is just a bad egg. Personally if they don't identify an obvious glitch like the ink being snapped in properly I would swap it at the store you bought it from and let them send it back to canon as defective.
