EOS-1 Ds Mark II ... Out Of Storage after 6 Years - NO Start Up ???
Discussion in 'Technical Troubleshooting' started by UpperCut, Aug 4, 2021.
  1. UpperCut
    UpperCut Active Member
    EF 75-300 1:4 - 5.6 IS USM,
    SIGMA 150-600mm Telephoto,
    SIGMA 150-500mm Telephoto,
    Hi there,
    Maybe somebody has an idea about what would be the next step as I have a 'EOS-1 Ds Mark II ... Out Of Storage after 6 Years - and unfortunately NO Start Up ??? Camera was running before it was put in storage ... rgs
    The first thing that springs to mind is what is the state of the battery? I am sure that you have charged them, but are they holding charge and or putting out enough power to start up your camera? Also, what are the terminals looking like? Are they clean?
  3. UpperCut
    Thanks, YES I have other EOS-1 so I have good batteries as well as new once, and each of them does work in other units yet NOTHING in that one! The small RED Light flashed once that is all, and the contact plates inside the B-Loader do look fine also. rgs
    Just as a random thought. What happens if you put a fully charged battery in it over night and see what happens tomorrow. Do these cameras have an internal battery?
  5. UpperCut
    Hi, thanks yes maybe try that ... yes they have a Time date battery as well I maybe will try one out of one other unit which does go! thanks rgs
  6. UpperCut
    Well, NO old small Timer battery had still power & a brand new one also did nothing! The RED light should flicker before switch on just as the others, but NO! rgs
  7. johnsey
    Check to mack sure the battery and card doors are latching properly. Cameras will not function if battery and CF card are not seated firmly and the door is not latching ...aka the door presses the button to register that the door is shut. That is my guess on what is happening here.
