EOS Rebel SL2 only working in auto mode
Discussion in 'Technical Troubleshooting' started by Babu, Oct 8, 2019.
  1. Babu
    Babu New Member
    EOS T2/200D
    Dear all,
    I am using eos rebel sl2/200d....after fews month using now it's showing some problem while shooting in other mode like manual,tv,p,etc not working its screen going blank & red colour light only blinking & can't take pictures...only working in auto mode.
    When clicking button in manual mode or tv or p mode camera screen automatically showing blank & only red light blinking....I check all settings & on/off the dslr remove card also...but problem is not solve.....plz help us guys......
    Unfortunately if the issue is a firmware/hardware issue there isn't much one can do but contact customer service. What you describing doesn't sound user related, it seems that turning the dial to other settings is causing some sort of fault in the wiring or the firmware on the camera. The only thing someone can try easily when they have glitches in software is re-install the firmware and see if it makes a difference.
    On the upside you mentioned you've only had it for several months so they should be able to repair or replace it under warranty.
