Going Wide
Discussion in 'Other Camera Brands' started by Marcus Rowland, Oct 28, 2019.
  1. Marcus Rowland
    London, United Kingdom
    I've been playing with some seriously silly photographic kit recently, stuff that starts with the idea of wide angle and takes it up to 11 or more.
    The first is a Cinemascope projector conversion lens mounted as a wide angle converter on an SLR. This works, except that you need a slightly long lens to start with - I ended up using a Helios 44-4 58mm Russian lens on my 400D, anything shorter had cropped corners in the final image, and something even longer might have been better.
    Unfortunately it's a bit of a pig to work with - you really need a tripod, the converter weighs more than a kilo, and with the camera, the lens, etc. you end up carrying about 5kg of kit. It's also very slow because for each shot you need to adjust the camera lens and the converter, and with this lens I had to bracket speed (because the lens has no connection to the camera's metering system), you have to keep everything dead level or there's distortion, etc. etc. I took 9 photos in the time it usually takes me for 50 or more when I'm testing something more conventional. Here's one:
    [​IMG]
    The rest of this batch are here:
    https://www.flickr.com/photos/150868539@N02/albums/72157711458861586/with/48945429152/
    The other one is fairly low-tech; a Lomography Spinner 360º 35mm camera, which takes incredibly wide negatives on 35mm film - the whole camera whizzes round with the film pulled past the lens as it goes. You get 8-9 photos on a 36-exposure roll, and if you aren't doing your own processing it soon gets seriously expensive. And Snappy Snaps etc. really don't want to have anything to do with scanning or printing them! Ideally you're supposed to include the sprockets in pictures since they're exposed, but in practice (after messing around with my flatbed scanner and getting nowhere, it's just way too low resolution) I ended up having to convert the images in my crappy slide scanner, which really didn't want to know about anything larger than a 35mm frame, then assemble the images using stitching software. It's a bit of a pain, especially if you haven't worked with film in umpteen years and are a bit cack-handed... Some interesting results, but there was a reason I switched to digital and this really hasn't changed my mind! This is actually more or less the same scene as the first, if you look carefully:
    [​IMG]
    The rest of the spinner photos are here:
    https://www.flickr.com/photos/150868539@N02/albums/72157711499565688
    I'm probably not going to be keeping this kit but it was fun to play with.
    Apologies if you see this more than once, I've posted something similar to the Nikon and Pentax forums.
    Craig Sherriff likes this.
    Might have been a bit of mucking around but the resulting photos are good
  3. Marcus Rowland
    Of the two I like the Cinemascope kit best, but the weight etc. and the complexity of using it is a bit of a turn-off. If there was a lighter anamorphic adapter that worked well with wider lenses I'd be a lot keener.
