Help! Is it possible to output video from DSLR to PC without losing quality?
Discussion in 'Technical Troubleshooting' started by condoriano12, Jan 16, 2025.
  1. condoriano12
    condoriano12 New Member
    t6i and t5i
    My current setup is a Canon T6i, and im sending the image to my PC through a HDMI and a capture card to be recorded using OBS. I tried all the best setting I could find, but the video quality is visibly inferior to the one I can get with the camera alone.
    Here's a comparison of a frame from OBS and a frame from the camera's card. Same angle, same light, same everything: https://imgur.com/a/YkXQOlB
    Is there anyway I can use this DSLR to stream my podcast in good quality?
  2. Alfred Pennyworth
    Alfred Pennyworth New Member
    Canon Mark IV
    Canon provides a free software called Canon EOS Webcam Utility that allows you to directly use the T6i as a webcam without an HDMI capture card. The quality might be better than a cheap capture card, though it’s still limited to 720p.
    Although if you want to stick with HDMI, use a high-quality capture card, like Elgato or AverMedia. Tweak OBS settings for better encoding.
