Is the equation "550d + sea water = RIP" correct?
Discussion in 'Technical Troubleshooting' started by le0nidas09, Jul 10, 2017.
  1. le0nidas09
    le0nidas09 New Member Site Supporter
    Canon 550D
    Canon 550d + sea water = RIP?
    Help!!
    I accidentally today put my 550d (or t2i) into the sea. I've done it many times before, but today there was a child nearby playing with the waves... so... although the water just touched the bottom of the lens/camera and I removed it immediately from the water, now it won't show any signs of life.
    I know, it's entirely my fault (I didn't even thought of complaining to that child)
    Now the thing is
    Battery is charging ok, sd card is ok (though I saw some wet signs there), but canon is dead (?).
    Please somebody help!
    You could try placing it in a sealed bag of dry rice to dry it out. But if you tried turning it on you may have fried it completely.
    pcake likes this.
  3. le0nidas09
    Canon 550D
    Thank you for your quick response..
    I did try to turn it on..
    I feel really depressed now..
    Anyway..
    I'll try to leave it for a day or so to dry, and then try my luck..
    Try the rice in sealed bag trick for few days, it will help a lot in drawing moisture out from inside. Its worth a shot at least.
  5. le0nidas09
    Canon 550D
    I am sure gonna try it..
    Either way there is no money left to get a new one, so I have to try anything!!
  6. le0nidas09
    Canon 550D
    After a few days, letting it dry, this happens.
    When I insert the battery, it makes a beeping sound for around 5 seconds, screen turns on but stays blank. All this without turning the dial to ON. When I turn it to ON, stays in the same condition.
    I removed the battery and then tried to do it again. The results are, no beeping sound, screen turns on for about a second, blank and thats it.
    Do you think there is still hope?
  7. Phil
    Rochester, NY
    Is the battery charged?
  8. le0nidas09
    Canon 550D
    Yes. Its fully charged.
  9. Phil
    Rochester, NY
    I would look at the battery contacts on the camera. Since it was in sea water (salt), it could be corroded already. Your symptoms make it seem like it's not getting enough power. If they look corroded, try taking a scotch brite pad to it to shine it back up.
  10. le0nidas09
    Canon 550D
    I hope this could be it.. I'll do it when I get home!
  11. le0nidas09
    Canon 550D
    Hey I got it to work today!! Although it takes photos/autofocuses/indications in the viewfinder are fine, it has some issues. The screen flickers sometimes and stays blank (except when I'm on liveview mode) and some buttons are unresponsive.. I'll let it dry some more and see what will happen!!
  12. Phil
    Rochester, NY
    What did you do to get it to work?
  13. le0nidas09
    Canon 550D
    I just let it dry...
    But I think nothing happened eventually. Today I reinserted the battery and nothing happened at all. Nothing turns on/no autofocus.
    Guess we're back at step 1 again.
    Maybe I'll try another battery eventually.
  14. Ray-UK
    Sorry to tell you but you are probably wasting your time.
    Immersion or sometimes just a splash of sea water is almost the worst thing that can happen to a camera, even if it works when it dries out then it will almost certainly fail later. As the sea water dries it leaves behind salt crystals, these crystals will spread across the printed circuit boards and wiring slowly corrode everything.
    Best to start saving up for a new camera and don't take it to the beach next time.
  15. le0nidas09
    Canon 550D
    Is there a way to clear these crystals? I heard that a contact cleaner solution / isopropyl alcohol might help. Is that true?
  16. Ray-UK
    It may be possible to clean it depending on where the water went, however it would need opening up and possibly some partial dismantling. Isopropol rubbed on vigorously with a small paintbrush would work, the sooner it is done the better, before the corrosion takes hold.
  17. le0nidas09
    Canon 550D
    Do two weeks count for soon enough??
    Guess not, right?
    Anyway, I'll try opening it tomorrow and see what I can do!
    Wish me luck!
  18. pcake
    pcake Active Member Site Supporter
    Canon SL1
    55-250 STM
    18-55 STM
    Yongnuo 50mm 1.8
    how'd that work out?
  19. le0nidas09
    Canon 550D
    I did it today morning..
    I will let it for one day to rest (myself too) and I'll be back!
  20. Ray-UK
    Careful use of a hairdrier can help remove moisture that is trapped in small places, although Isopropyl evaporates pretty fast anyway..
