lens advice please
Discussion in 'Technical Troubleshooting' started by keith1955, Jun 22, 2021.
  1. keith1955
    keith1955 New Member
    chesterfield england
    canon 90d body , canon ef 50mm f/1.4 ideal for portrait and close up ,canon ef 50mm f/1.8 for general use , a canon 24 to 105 and a canon ef 100-400mm f/4.5-5.6L IS MKII lens for wildlife and dolphin watching in Scotland , i also have a 1.4 extender for the 100 to 400
    i have a 90d body , i want an 800mm lens but the canon one is £13k ouch !
    canon make an rf 800 lens. Is it possible to get an adaptor so that i can use the rf 800 lens
    i doubt there is an adapter, its also an ƒ11 lens, this is ok for the R series but the lesser mounts might struggle
    how about going with a sigma 100-400mm and a canon 2x converter
    i used that combo for the image below, just a jpeg so if you shoot raw it will probably be better still
    that being said if you can stretch your budget to a sigma 150-600mm and dump a x2 on it you will be well over your planned 800mm
    The RF uses a shorter flange distance, there will not be an adapter.
    That 800mm 5.6 need 5.6in of diameter to its aperture, its all just basic math. So you end up with a gigantic expensive lens in the L lineup. At f11 you only need a 2.86 inch diameter aperture wide open, its a much easier and smaller lens to produce.
    The is no perfect way to get that long of reach, you can see why if you want a good L lens at 800mm it will cost money for the better quality and usability.
    1.You can buy a shorter lens and use an extender, but they suck light and will take away some IQ. And a good extender will cost a fair amount of money.
    2. You can always crop a image down if you have the resolution to do so.
    3. You can by a super zoom bridge camera just for these type of shots, also cost money, and I recommend going all the way to 2000-3000mm super zooms so you can crop and sharpen a bit as the quality will fall off on the long end also.
    Options 1&3 are probably the best bet depending on if you can find a good 400/500/600 lens for a good price and it performs well. The 2x extender pulls out 2 stops of light quickly changing your f4 to f8 and not all cameras can focus at f8 or darker.
