Lock a 1D mk2 settings
Discussion in 'Beginner Questions' started by MillerstreetFX, Nov 30, 2022.
  1. MillerstreetFX
    MillerstreetFX New Member
    Canon 1d mkii
    Canon r3
    too many lenses to list
    All,
    I've searched for this, still unable to find an answer.
    Question is how do I (or 'can' I) lock the current settings when shooting so that if my fingers get twitchy I don't ramp up the shutter to 1/6400/s instead of say, 1/1600. Aperture also.
    Also procedures on the R3 if it can do it. That thing gets bumped ALL the time. I blame big hands... :)
    Thanks!
    welcome to the forum, MillerstreetFX, I do not think you can, but with a bit of tape and a small piece of cardboard, make a little cover up, set your shutter speed then cover the jog wheel. This may be a solution to the problem.
    By design as a photographer you also want to quickly change settings while shooting so I don't see a good way to design it both ways. I guess a lock switch would be ideal that disables everything but the shutter.
    But, depending on the subject, you could setup a tripod and use a remote to trigger, then you would not fumble the settings. :D
