Teleconverter "AGAIN"
Discussion in 'Beginner Questions' started by Pete.c, Jul 11, 2019.
  1. Pete.c
    Pete.c Member
    Canon Eos 5D iv, Canon EOS 77D, Canon 10 - 18mm, Sigma 17-70mm, Sigma 105mm macro, Sigma 70 - 300mm, Tamron 150-600mm F/5-6.3, Canon 50mm 1.8 STM
    Hi guys,
    Sorry for bothering you again with this subject, being a beginner I'm a bit of a numb skull.
    I have a sigma lens with a f5.6 what will the size be with a 1.4x converter
    . And the second question is I have a sigma lens with f6.3 what would the size be with a 1.4x converter.
    I don't want to pass f8 as I would loose auto focus. And I don't want to waste my money as I need it to be auto focus.
    Thank you all.
    Pete.
    You will lose 1 stop of light with a 1.4, 2 if you had a 2.0. This is because you extended the length of the lens with this added barrel. At 6.3 will be effectively as dark as using it at 8 without the converter. Hope this helps.
  3. Pete.c
    Pete.c Member
    So it looks like I can use a teleconverter then. Hopefully. Just as I have notice the stop working at f8.
  4. Pete.c
    Pete.c Member
    Hi guys,
    Well I purchased a 1.4x converter, only a cheap one so I didn't was my money if it didn't work . And it works just fine it even worked up to f11, can't understand how, but mainly at f9. So shortly a better quality teleconverter will be purchased.
    Thanks all for your help.
    Pete
