Using Olympus lenses on my EOS 70D
Discussion in 'Canon Lens Discussion' started by Clive, Sep 27, 2020.
  1. Clive
    Clive New Member
    Canon EOS 70D
    I've just bought my first Canon camera - very pleased by the way, but have a couple of old lenses that originally graced my Olympus e20, which use 62mm threads. I've looked everywhere, but can't anything specific pointing to a suitable adapter. Is the idea feasible ? If so, where might I get one.
    Thanks.
    I thought the Olympus e20 was a bridge camera meaning it had a single fixed lens. It did have a 62mm filter thread which is a pretty common filter size.
  3. GDN
    What are these lenses that you have? Any chance of an picture or two of them?
    Clive, I think you might be running into a bit of trouble if the setting of the aperture is reliant on the camera's software, the lens has to communicate with the camera and if you have two different brands, there can be conflict. Now if your aperture is manually done, then it may work by placing the camera in Aperture Priority, set the aperture and the camera will do the rest or set it in manual and take it from there. If one is available then Ebay will be your first port of call.
  5. Clive
    Clive New Member
    Canon EOS 70D
    Hi everyone,
    Appreciate the replies and advice. I've already got two good zoom lenses from Canon.
    They'll satisfy my needs! The Olympus lenses were good, but intended for the Olympus e10 or e20 -
    a lifetime ago.
    Cheers
    Clive
