Viewfinder grid display 80D
Discussion in 'Technical Troubleshooting' started by Traveller3216, Mar 4, 2019.
  1. Traveller3216
    Traveller3216 New Member
    EOS 80D
    Hi on my 80D I was able to see 3 different grid patterns in the viewfinder. 3x3, 6x4 and 3x3+ diagonal. After making some adjust to other settings I can no longer see these. Canon helpdesk tells me these grids are only available in Liveview. I disagree as they were definitely in the viewfinder as well. How do I make them visible again? And yes, in the Viewfinder Display option I do have it set to Show.
  2. porkphoto
    What other adjustments and to what feature did you change, this info might help us steer us in the right direction to help you.
  3. rayallen
    I would suggest doing a reset to factory settings. I'm not sure where that would be on an 80D but it will be there somewhere.
  4. Traveller3216
    EOS 80D
    I have already done that several times, with nil effect.
  5. Traveller3216
    EOS 80D
    I was having a "general" play around, so honestly cannot be certain which parameters I have changed.
    Look up the viewfinder in the user manual... There's a number of things you can do like turn on an electronic level.
    As to turning on your grid...
  7. Traveller3216
    EOS 80D
    Thanks johnsey. I have done that but it's not resolving the issue
  8. porkphoto
    If you have Face + Tracking selected I believe the 80d will disable grid in the view finder. Try selecting another mode.
