Is the equation "550d + sea water = RIP" correct?
Discussion in 'Technical Troubleshooting' started by le0nidas09, Jul 10, 2017.
  1. le0nidas09
    le0nidas09 New Member Site Supporter
    Canon 550D
    Sorry taking so long to post, but I'm nowhere near home the last few days.
    Anyway.. After all this trouble, nothing really changed.
    When I insert the battery sometimes it beeps, sometimes not. Sometimes turns on, sometimes not.
    Maybe its time to try a new battery? Maybe its eventually the end?
    I'll order one battery from ebay so it might take a while for a new post update.
    And I'll try to save some money for a new one in the worst case scenario.
    Maybe buy a used 550d again or upgrade to a newer model.. I was quite happy with the 550d so I never got in the mood to buy a new one, so any suggestions would be useful (but this is another category-so I'll stick to my problem in this post)..
    The new battery is a inexpensive test, but to be honest it is highly unlikely that it has anything to do with the camera issues. And once a circuit board is fried its not coming back to normal again. If your on a budget maybe you can find same/similar model on Craigslist or something?
    Otherwise suggestions would be based on what you want and your budget.
  3. le0nidas09
    Canon 550D
    Well... I tried today to turn it on again today, in case any moisture left was gone.
    Nothing happened.
    Then I got angry and started shaking the camera...
    Then it magically turned on...
    Everything worked perfect... but only for a while.
    So after removing the battery again (which was already fully charged) and reinserting it, nothing happened for one more time.
    I left it for a while and then tried again.
    Then for the first time, this message came up in the lcd screen: "Change battery pack!" (or sth like this - I dont remember the exact sentence)
    So, maybe it's just a battery issue and not a fried circuit after all or maybe I'm just refusing to face reality (again :):):))
    I ordered just now a new battery from ebay..
    Till then I'm gonna pray!!!
  4. Ray-UK
    Have you tried cleaning the battery contacts, both the battery and in the camera. Sometimes you get a layer of oxidisation on them that is not visible but a wipe with isopropyl can cure the problem.
    If you got it going by shaking it then it sounds like connection problem, it may even be one of the circuit board fixing screws are loose or have some corrosion underneath that is preventing a proper ground connection.
    pcake likes this.
  5. le0nidas09
    Canon 550D
    I really don't know..
    I wait for the battery now and see.
    For now the only way it starts is by shaking it.
    Probably a corrosion problem as you mention, since I doubt anything is loose since I treated my camera all these years like a newborn.
    If the problem persists with the new battery, maybe its that. If not, it is a battery problem.
    The other thing thats strange, is that the first screen that appears when I turn the camera on is the choice of WB. Like I pressed the WB button. After I press OK, all works fine, except the WB button that is completely unresponsive..
    And the screen sometimes switches off.
    I recharged the battery again today, and while it should be completely empty (as the camera stated), it got fully charged in about half an hour.. Sooooo it is very probable that the battery itself is off in my opinion..
    I'll wait for the new battery and see anyway.
    PS. I found my old Zenit today.. After 8 years I'm gonna try analog again!! But first I have to buy some film first! Hope I can make it today!
    Water can cause electronic damage in two ways, corrosion from oxidation; and from IONs in normal water which conducting electricity causing the the circuitry to short out.
    The WB at turn on and the intermittent working if shaken is not really a surprise at all. These sort of reactions are common when electronics are shorted out, causing all l sorts of misreading in the circuitry.
    Water damage due to corrosion really should not apply to the case of a camera or phone getting wet and not turning on, corrosion hasn't taken place yet. However if the electronic was ruining or you try turingin it on before the item was thoroughly dried you have a very high chance of shorting it out. And the only way to fix that would be to replace what got shorted.
  7. le0nidas09
    Canon 550D
    Well.. Sorry it took me so long to post a reply..
    The situation is like this..
    The battery I ordered never came, so I got a refund. In the meanwhile, the camera started to work again every time, except for the things that went faulty after the "bath".. The UP (WB) button, the microphone (don't have sound in the videos anymore) and another thing that came up lately is that it doesn't keep the date. So everytime I remove the battery to charge it, it prompts me to enter the date.
    Other than that, it works fine.
    Thats it.
    Thank you everybody very much for the support and the solutions given!
    Really appreciated it!
  8. Phil
    Rochester, NY
    Your problem might be as simple as the small battery that keeps the date. I know in my 7D there's a slot for a button battery inside the main battery compartment. You might be able to just replace that battery and it will keep the date!
