Night and Stars Jupiter from London
Discussion in 'Post Your Photos' started by Caladina, Jun 23, 2021.
  1. Caladina
    yeah i'm well aware of the optical resolution limitations, its an mid / entry level camera with a similar level lens, i dare say if i had higher level camera and a pro glass of the same length i could do better but those are out of my reach as a hobbyist,
    too cloudy for another go tonight
    as for a tracker i might get a smaller one for smaller lenses leaving the heavier payload trackers for the futre if i get a scope for doing planetary stuff. happy to see what i can get with what i have atm
  2. Sundar Amartur
    Canon EOS 6D
    Canon EF 24-70mm f/4L
    Canon EF 70-300mm f/4
    Canon EF50mm f/1.8
    Rokinon 14mm f/2.8
    Canon EF 24mm f/2.8
    Pentax gear
    It is fun pushing the envelope with what we have. Thanks.
    at the other end of the spectrum this is 2mm of ruler on the M50 sensor uncropped jpeg straight from camera using the same lens
  4. Sundar Amartur
    Canon EOS 6D
    Canon EF50mm f/1.8
    Rokinon 14mm f/2.8
    Canon EF 24mm f/2.8
    Pentax gear
    Now you are ready for some crawlers in your garden :)
    just got one quick shot of Saturn before the clouds rolled in
    ƒ8, ss1/30, iso100
    well she is 842740667 miles away and traveling at 21,637 miles per hour
    Paul F and GDN like this.
    Another impressive image from the gear you are using.
    Again, any chance of seeing the uncropped image?
  7. Caladina
    Its in the center
  8. GDN
    I can see a little dot in a see of black. I think that you are doing really well with where you are living and what gear you are using.
  9. Craig Sherriff
    You lucky thing, a bit of clear sky, all we have down here in Tasmania is cloud and a bit of ran.
  10. Caladina
    i have a cunning plan........... lets see if it works
  11. Craig Sherriff
    Sounds like Balldrick off of Black Adder
  12. Caladina
    loool, when i posted that i was looking for a Doc Emmett Brown clip to go with it from back to the future
  13. Caladina
    jupiter tonight, slight improvement, was able to shoot from a neighbors garden so i could avoid the street lights
    sigma 150-600mm @600m ƒ6.3 1/60, iso100
  14. GDN
    Well done with the equipment and in the environment that you are based in.
    Yell out when you are coming over and I will take you out to a place with little to no light pollution.
